Webcast-Catalyst9k
ErrorRate/DiscardRate
How does DFM get these counters? I keep getting alerted on high discard rates and error rates on etherchannel interfaces...but I'm not seeing any errors or dropped packets on them when I log on to the switch.
1 REPLY
Re: ErrorRate/DiscardRate
High Discard rate is calculated using the formula:
HighDiscardRate = ( InputPacketDiscardPct > DiscardThreshold || OutputPacketDiscardPct > DiscardThreshold)
A discard rate is calculated using:
PacketDiscardRate / PacketQueueRate * 100
The discard rate is built using if{In,Out}Discards over the polling interval. The packet queue rate is build using if{In,Out}UcastPkts + if{In,Out}NUcastPkts + if{In,Out}Discards over the polling interval.
HighErrorRate is built using the formula:
(InputPacketErrorPct > ErrorThreshold || OutputPacketErrorPct > ErrorThreshold)
The PacketErrorPct is built using:
PacketErrorRate / PacketRate * 100
PacketRate is either the input or output utilization, and PacketErrorRate uses the following objects based on the interface type:
if{In,Out}Errors
dot3StatsFCSErrors
dot3StatsInternalMacReceiveErrors
dot3StatsAlignmentErrors
dot3StatsFrameTooLongs
dot3StatsCarrierSenseErrors
dot3StatsInternalMacTransmitErrors
469
