Ethernet Switch with an IP/MAC Address
Dear sir,
Im VishnuKarthick from Siemens India,
Im looking for an Ethernet switch for one of my project.
My basic requirement is to Connect two or more Ethernet Nodes(Siemens Programmable logic Controllers) to a common Ethernet Switch which has an IP/MAC Address. This Switch will be connected to a Server Containing Siemens Software which has to access the PLC System.
The IDEA behind this is Even one of the Ethernet Node fails, The Siemens Server will access the PLC nodes through the common IP address of the Switch.
Do you have any product which features the above mentioned functionality??
Any one Please Suggest.
Thank you,
Vishnu Karthick,
Siemens Bangalore,
India.
282
