Webcast-Catalyst9k
Eval LMS 4.2 with 403 Forbidden Error
I'm trying to get LMS 4.2 up and running to eventually eval the compliance license features that are not in PI yet.  However, upon install 4.2 twice now, I get the 403 Forbidden error message (in firefox and IE) when trying to get to use https, http doesn't go anywhere.  I found the below fix in several places, but get no where with it, as I get this error on the perl command:
Can't locate CRM.pm in @INC (ect ect) at bin/ConfigSSL.pl line 6.
I'm not sure what to do, I hate wasting time to try and get an eval to work.  Any help is appreciated, thank you.
Hi ,
Try to Regenerate SSL certificates:
1)       Stop the daemons manager from CLI using /etc/init.d/dmgtd stop
2)       Backup the following files found in /opt/CSCOpx/MDC/Apache/conf/ssl and
then delete:
server.crt
server.csr
server.key
server.pk8
Under CLI go to "\opt\CSCOpx\MDC\Apache\" and then run ConfigSSL.pl by typed the following
command on CLI.
CSCOpx\MDC\Apache\perl configssl.pl -disable
CSCOpx\MDC\Apache\perl configssl.pl -enable
Then fill the certificate accordingly and restart daemons from CLI using net
start the daemon manager:
Thanks-
Afroz
Silver
Make sure /MDC/tomcat/conf/catalina.properties has correct value of NMSROOT in all path settings.
So why do I have to make all these changes on a fresh install of LMS 4.2?  Is there not an updated install that correct these issues, I'm simply evaling?
I don't understand where needs to be put to get it to run?
Hi .
The error you are getting  while enabling the SSL is a SYNTAX error:
run the command as below:
/opt/CSCOpx/MDC/Apache/bin > /opt/CSCOpx/bin/perl ConfigSSL.pl -enable
This should work.
Thanks-
Afroz
[Do rate the useful post]
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
It works. Thanks!
370
