Community Member
Exclude devices based on devices name
My LMS version is 3.0.1, running on Windows systems.
I have deleted some devices because of alias devices. But after running discover devices, devices that I have deleted appears again. I try to configure discovery setting >filter setting,but I couldn't find exclude device based on device name. How to exclude devices based on device name?
1 ACCEPTED SOLUTION
Re: Exclude devices based on devices name
You're executing it incorrectly. First, delete C:\PROGRA~1\CSCOpx\bin\perl (not perl.exe, but perl). Then run:
D:\PROGRA~1\CSCOpx\bin\perl.exe CSCsm66330-0.pl
It sounds like you're running into CSCsm66330 which is fixed in LMS 3.1. However, you can exclude devices by hostname from being imported to DCR by creating an excluded device CSV file, and importing it under Common Services > Device and Credentials > Device Management > Exclude Devices.
Community Member
I can't find the link for download LMS 3.1. The last version is LMS 3.0 Dec 2007 Updates (http://www.cisco.com/kobayashi/sw-center/cw2000/lan-planner.shtml). Can you give me the link for LMS 3.1?
If you have a SAS contract covering LMS 3.0, you can go to http://www.cisco.com/upgrade/ , enter your contract number, and request the DVD be shipped to you. If you do not get the option to get the 3.1 DVD, then contact your sales team.
Community Member
I try to download cwcs3.1.1-win-CSCsm66330-0.zip, but I couldn't install the patch. Am I wrong when executed the command? Please see attached
140
