Export topology view
From topology view, I have change the topology (using username "A"), can I export topology to the other user (using username "B") so if I using username "B", the topology view will be the same as if I using username "A".
1 ACCEPTED SOLUTION
Re: Export topology view
The topology layout can be shared with another user by copying the *.xml files under NMSROOT/campus/etc/users/A to NMSROOT/campus/etc/users/B. You will probably also want to copy the user.preference file.
Right now I can shared my topology layout for the other users. Thank You so much.
109
