Community Member
Extraneous devices in Inventory
The inventory collection has picked up a number of interfaces from our core switches. However there is no way to delete these as they do not appear in the DCR or as RME Devices. How can these be cleared from the database?
1 ACCEPTED SOLUTION
Re: Extraneous devices in Inventory
Yes, this is possible.  Just set AAA Mode to Local, but leave the TACACS+ login module selected.
Is LMS integrated with ACS?
Community Member
Yes - it is currently integrated with ACS v4.2
Chances are those phantom devices are not known to ACS.  To correct this, temporarily disable ACS integration, then login to LMS and clean up DCR.  Note: this may also help your alias problem you mentioned in the other thread.  When DCR looks the way you want, re-enable ACS integration.
Community Member
Joe - is it possible to break the integration with ACS, but still have Ciscoworks user authentication through ACS?
199
