04-20-2009 06:29 AM
I have lms 3.1 with RME 4.0 and I cannot do an inventory with VS-S720-10G.
Do i need to upgrade RME. With patch do I need : "consolidated IDU 22" ?
Thanks for your answer
Michel Misonne
04-20-2009 06:46 AM
What version of code in this switch running?
04-20-2009 06:49 AM
hi here is the version : s72033-advipservicesk9_wan-mz.122-33.SXI.bin
04-20-2009 06:53 AM
You are most likely seeing CSCsx58694. A patch for this bug is available by contacting the TAC.
04-20-2009 07:06 AM
According to the Supported Device Table for LMS 3.1 (http://www.cisco.com/en/US/docs/net_mgmt/ciscoworks_lan_management_solution/3.1/device_support/table/lms31sdt.html), the SUP 720 (sysObjectID 1.3.6.1.4.1.9.5.44) is NOT supported under RME. However, the Catalyst 6500 (sysObject ID 1.3.6.1.4.1.9.1.283) IS supported.
