09-12-2005 07:00 PM
When requested to delete a link or a device in CM3.3 topology service window( running under Common Service 2.2, with IDU 11 installed), a message on the status show ' request to delete 1 device(link) accepted' but the device was not deleted.
Is it a new bug? since I havn't found relate bug information with bug tool kit.How to due with it?
Solved! Go to Solution.
09-16-2005 06:20 AM
This no defect in Campus manager. Its due to the usuage of Java. If you are deleting from a map, refresh the map. If from tree or summary, reload the same. It will get updated.
09-16-2005 06:20 AM
09-17-2005 05:58 PM
That's for sure.
Thanks Chen!
