Community Member
Failed to enable Netflow in Physical Interface
Our customer said they failed to enable Netflow on their physical interface but success on vlan. Currently they use 12.2(33)SRB1 image on 7600 series. Is there any suggestion for this issue ?
Blue
Re: Failed to enable Netflow in Physical Interface
There's not enough details (module type and configs involved) to go on, but if "physical" means a layer-2 interface, of course that won't work.
Bronze
as wrote yjdabear, on 7600 you need to enable netflow on all L3 interfaces (you get the list via: show ip interface brief | exc unassign
and also enable mls nde export:
mls netflow
mls flow ip interface-full
mls nde ...
Don't enable NetFlow on L2 ports...
See more infromation about configuration on the URL:
http://netflow.caligare.com/configuration_native.htm
Kind regards,
Jan Nejman
Caligare, Co.
http://www.caligare.com/
Community Member
Hi nejman and yjdabear,
What I mean, physical interface mean physical port (Gi). We are on network monitoring side and configuration handle by different group. They said the configuration : ip route-cache
flow" or "ip flow ingress" only can apply on vlan interface (L2) and not on physical interface. I have read your url configuration and so far I don't see any limitation to enable it on Gi interface. Please correct me ?
Bronze
physical port can be configured as switched port (layer 2) or with an IP address (layer 3).
On 7600 you need to enable netflow on all L3 interfaces (no matter if it is VLAN or physical interface, enable netflow on all L3 interfaces). You get the list of these interfaces via command: show ip interface brief | exc unassign
i.e.:
interface Vlan100
interface GigibitEth0/1
You also need enable mls netflow export. mls is running in PFC (supervisor) and 99% of flows is exported from mls cache. See documentation how to enable netflow export from mls.
Jan
300
