Failure Archiving Device Configs...
Hi Everyone, I am having issues archiving configs for some of my devices. I am using Ciscoworks 3.1 and RME 4.2.0
I am getting the following error:
"Could not detect SSH protocols running on the device TELNET: Failed to establish TELNET connection to (Device IP) - Cause: Connection refused."
I can connect with SSH to the device using the credentials I have in Ciscoworks.
Does anyone know what could be causing this?
Re: Failure Archiving Device Configs...
What type of device is this? What version of code is it running?
We have 3750-24P running c3750-ipservicesk9-mz.122-46.SE, a 2851 router running c2800nm-ipbasek9-mz.124-15.T7.bin, and a 3750-24P running c3750-ipservicesk9-mz.122-35.SE5. We also have other devices with the same version of code and those are working great.
Telnet to port 22 of these devices. What output do you get?
Hi Clarke, I am getting the following output. We have telnet disabled and have SSH enabled on the devices.
SSH-2.99-Cisco-1.25
That's what I thought. This is a known device bug, CSCsq51052. As a workaround, you will need to disable SSHv2 (i.e. no ip ssh version 2).
Hi Clarke, I disabled SSHv2, then enabled it again. I am now able to archive their configs successfully. Thanks for all your help.
290
