File system is filing up in LMS2.6
I have about 3 gig in use in the following directory. Is it safe to delete that. Since there are not the log files, is there a way to automatically delete these files when they grow certain size?
/var/adm/CSCOpx/file/rme/cri/archives
Re: File system is filing up in LMS2.6
These are archived reports. It is best to delete these from RME > Reports > Report Archives.
Can I do it thorugh the command line? I have 2500+ records to delete.
There is no command line interface to remove report archives. However, you can select the checkbox in the header (next to Report Type), and that will check all archived reports automatically.
126
