Force LES selection using WIC-2A/S
Is there a way to force the a Land Earth Station (to force the call to go through a different provider) when using an INMARSAT Dialing solution.
In a nutshell, suppose the the default LES used for all current IMARSAT communications is LES 1, our dial string would be similar to '0011231234567#'.  Now, if I wanted to force the call to use LES 2 without changing the current SAT-B settings, how would that be accomplished?  I have tried using 02*0011231234567#' and it appears that teh '02*' portion is causing the errors.
We are using the following equipment:
2800 series router with the 12.4(25c) IOS
WIC-2A/S card
Thanks in advance for any assistance.
Everyone's tags (4)
198
