04-07-2006 05:42 PM
I have a client who has forgotten or lost the login and password for his current internet router.
Do the procedures differ from device make to device make or is there a "all in one" solution to resolve such issues as forgotten or lost user names and/or passwords to access the Cisco IOS software?
04-07-2006 05:59 PM
The password recovery procedure does depend on the actual platform to some extent. What sort of device are we talking about here ?
Paresh
04-10-2006 04:13 AM
Thanks for the reply.
The router model is: 1721
04-10-2006 04:48 AM
Password recovery for the 1700 series is located at:
04-07-2006 06:04 PM
Password recovery procedure is not the same across all platforms. Some apply to a set of devices and some may apply only to a specific platform.
You can do a search on CCO with the keyword 'password recovery procedure (platform #)'.
Pls. rate all helpful posts.
HTH,
Sundar
