forward kiwi syslog logging to CW
Any one know how to setup and forward kiwisyslog messages to Ciscoworks server?
Much appreciated if you can point me to the right documents. Thanks
Re: forward kiwi syslog logging to CW
Yes you can forward the syslog messages to any other host,check out the belwo link with screen shot how to achive the same.Hope this solves your query !!
http://www.kiwisyslog.com/images/stories/products/screenshots/SyslogDaemon/syslog_setup_action_forward.png
Ganesh.H
Hi Thanks for your reply.
I have configured kiwisyslog to forward logs to CW. Now how do I setup CW so it can receive the logs, are there any doco that explain to to do this?
I would like CW to grab the logs from kiwi and display it in the portal.
Cheers
Check out the below link on cisco works to configure of sylog server,hope that helps out your query !!
http://www.cisco.com/en/US/products/sw/cscowork/ps2073/products_tech_note09186a00800a7275.shtml#topic4
If helpful do rate the valauble post.
Ganesh.H
394
