Community Member
Gatekeeper Clustering in Cisco Works Voice Manager 3.0
Hi Everyone,
I read the entire Voice Manager Documentation and I don?t find anything about how to configure the Gatekeeper if it is using Clustering. I found just Gatekeeper with HRSP, which is not my case.
What should I do ?
1) Install the Gateways in a group
2) Install the Gateways with just the main gatekeeper
3) Another option.
My main concern is about the automatic configuration done when you configure an gateway and that information can be replicate with the gatekeeper by CWVM.
Is that work with an "normal configuration" or works too with a Clustering Gatekeeper configuration.
Thanks in Advanced and sorry for my long message,
Andre Lomonaco
Bronze
Re: Gatekeeper Clustering in Cisco Works Voice Manager 3.0
Community Member
Hi Beth Martin
Thanks a lot for your reply and the link.
I know how can I configure Gatekeeper Clustering on IOS, but I wanna to know if the voice manager 3.0 has the knowledge to do it for me via Voice Manager console, but the Voice Manager doesn't know the Gatekeeper Clustering commands, line cluster, element, etc.
Anyway ,thanks a lot for your reply
Andre Lomonaco
144
