Webcast-Catalyst9k
Get both IOS and CatOS devices running-config
Hi everibody
It´s possible to obtain the archive running-config ( or startup-config)from catos and IOS devices and sent to my email or a folder on my PC once a week using Cisco works LMS 2.5.1
Any idea about that ?
best regards
Manuel
Bronze
Re: Get both IOS and CatOS devices running-config
I dont think this is possible. You can do an automatic backup to a server using any SNMP managent software.
U can use Kiwi Cat tools it works.
Mayur
86
