Getting CNA to Work on 4507 Switch
tapeterson
Wondering how to get Cisco Network Assistant on a Cisco 4507 switch.
Have Added:
4507(config)#ip http server
Do I need to add an access list?
4507(config)#access-list 75 permit 10.12.15.65 (IP being my PC)
4507(config)#access-list 75 deny any
4507(config)#access-class 75
Running version 12.2(20)EW
I can get into CNA, and it brings up the toplogy window and it states that it's an unsuported device.
I am running CNA 5.4
I am missing something
abacio
Thank you for including detailed information.
The Catalyst 4507R is definitely supported: the minimum IOS version is 12.2(20)EWA.
Unfortunately, 12.2(20)EW is not supported.
On the bright side, no access list is inherently needed. That is, if your PC can normally ping the switch and the HTTP server is enabled, no further configuration is necessary.
Here is a link to the release notes in which the minimum IOS versions are listed:
http://www.cisco.com/en/US/docs/net_mgmt/cisco_network_assistant/version5_0/release/notes/OL12210a.html#wp670016
Sincerely,
// abacio
abacio
Sincerely,
// abacio
Thanks for the fast response.
Our pleasure! Thank you (again) for including such relevant information. Your post may answer the questions for many others.
SIncerely,
// abacio
