Gigabit transceivers -
Take a look at the transceiver in the link below.
http://www.cisco.com/en/US/products/hw/modules/ps5455/products_data_sheet0900aecd8033f885.html
I have a hard time believing no show commands can be executed to see if and where in a module these transceivers are connected.
I could understand if a serial number for the transciever doesn't show but surely a show command would indicate the presence of one.
Silver
Re: Gigabit transceivers -
Hi Rob
I'm not sure if this works for SFP transceivers but it does for GBICs.
You can see some info about transceivers installed in a module, i.e:
sh int giga3/16
GigabitEthernet3/16 is administratively down, line protocol is down (disabled)
Hardware is C6k 1000Mb 802.3, address is ....
Keepalive set (10 sec)
Full-duplex, 1000Mb/s, media type is LH...
If no transceiver is present the "media type is LH" information is not shown
Also you can use:
sh int giga3/16 cap
GigabitEthernet3/16
Model: WS-X6516-GBIC
Type: 1000BaseLH
Speed: 1000
Duplex: full
Trunk encap. type: ....
Here you can also see type.
If you are looking for another kind of information you could check this:
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat4000/12_2_25s/cmdref/show1.htm#wp1983028
Good question.
Unfortunately I'm not aware of the relevant command.
You can do a quick check on types installed by doing
sh int | i SX or sh int | i LX
but this doesn't show the associated interface.
Only way I know is to look at each interface
sh int gigx/x
Peter
Thanks for the input and clarification.
164
