03-29-2012 09:04 AM
We are using LMS 2.6 in Windows 2003 server. Common Services showing 17 group members of RME created group but Campus Manager showing 16 group members of the same group. Please find herewith the attachments.
We need same number of members in the group.
03-29-2012 11:34 AM
Is this a user defined group just in CS? Or if you have defined another group in campus as well?
Seems to be two different groups made, hence I would request you to check the Rules for Campus if the missind N24PGNS_DHQ_SWITCH matches the rule policy or not.
if just CS made user defined group, try deleting the missing device manually and re-add this again and check.
Also, as a suggestion I would recommend you to try upgrade your LMS as 2.6 is EOL/EOS now.
-Thanks
03-29-2012 08:37 PM
04-03-2012 01:09 AM
04-03-2012 03:03 AM
there have been a few problems with Campus OGS in LMS 2.5 / LMS 2.6 ....
try to just restart CampusOGSServer and see if the problem is gone; - issue the following commands in a DOS box:
pdterm CampusOGSServer
pdexec CampusOGSServer
04-03-2012 09:30 AM
04-03-2012 10:39 AM
there is a procedure to drop the Campus OGS tables and recreate them, but you will loose your custom groups in Campus; I am not sure if this would affect you, because you wrote about groups created in RME, - do you have custom groups defined in Campus, also?
in any case, if you decide to go this way, you should have a known good system backup, in case of....
Can you post your CampusOGSServer.log and CampusOGSClient.log
