Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Have CW Small Network Management Solution restricted support devices ?
In CCO there is diferent information around number of restricted support devices in CW Small NM solution. Ii seems is limited to 40 devices but in the other hand you can read in some Q&A that this limitation is to 20...? so
Anybody have tested in real life this limmitation? beyond manuals and pdf's?
Silver
Re: Have CW Small Network Management Solution restricted support
Hi Raul,
the SNMS 1.5.1 is limited to 40 devices.
The CNA is limited to 20 devices.
Thats for sure. I had installations about 30 devices with the SNMS.
http://www.cisco.com/en/US/products/sw/cscowork/ps2408/prod_bulletin0900aecd8028b862.html
Read in table 4 the entry "CWSNM-1.5-K9"
Hope that helps.
Best regards,
Frank
Hello Frank
Your answer is really helpful!
Thanks a lot!
muchas gracias
111
