Help in LMS 3.0
1- I configured LMS 3.0 support 5000 node I am running discovery and discovered the nods
2- I have 100 branches connected over frame relay
3- I have 2 deferent frame relay cloud (redundant links)
4- I don't have DNS in my network
5- I discover by Ethernet IPs
MY question
1 - All discovery nodes have IP and I need names how I can resolve IP to name with out DNS
2 - All nodes in topology single nodes not like point to multi point or star I cant see the frame relay in topology between headquarter and anther branches
Re: Help in LMS 3.0
You can still have name resolution without DNS. To do this, you need to setup a hosts file on the server that maps IPs to hostnames (i.e. /etc/hosts on Solaris and C:\WINDOWS\system32\drivers\etc\hosts on Windows).
For Topology to work properly, you need to have CDP enabled. CDP is not enabled by default on frame-relay multipoint interfaces, so you will need to explicitly configure "cdp enable" under those interfaces.
Re: Help in LMS 3.0
The HQ to branches connection is
• FR "Point-to-Point" configured on the sub interfaces.
So just to enable CDP it will work like point to multi point
Re: Help in LMS 3.0
If you manually enable CDP on those interfaces such that show cdp neighbor looks like you want it to, then run a new Data Collection, you should see the interconnections on your topology map.
150
