Help - Internetwork Perfomance Manager - config failed
hi, I keep getting a config failed status. how can I check if my source device supports the operations or has enough memory?
Silver
Re: Help - Internetwork Perfomance Manager - config failed
For IOS releases that support IPSLA look at the presentation look here
http://www.cisco.com/en/US/products/ps6602/products_ios_protocol_group_home.html
Depending on the version of you IOS you should look for "rtr responder" or "ipsla resopnder" when you're in the global section of config mode. It has to be enabled on the device prior to you deploying any probes to it.
ok thanks, I'll look into that
99
