Help with Ciscoworks
I am currently running the latest version of Ciscoworks and have not been able to locate any information that says I can tftp my configs from cisco works to a backup tftp server. Also the docs state that the shadow directory should be saving my configs in clear text but it does not seem to be doing that. What am I doing incorrectly?
1 REPLY
Hall of Fame Super Silver
Re: Help with Ciscoworks
The shadow configs are not saved by default under LMS 2.5.
From an earlier post (tip o' the hat to davistan), here is how to enable it:
Stop the ConfigMgmtServer process. To do this follow this procedure:
Select Common Services > Server > Admin > Processes.
The Process Management dialog box appears.
Select the ConfigMgmtServer process.
Click Stop.
Select Resource Manager Essentials > Admin > Config Mgmt > Archive Mgmt.
The Archive Settings dialog box appears.
Select the Enable Shadow Directory check box.
Click Apply.
A message shows that the changes were made.
Restart the ConfigMgmtServer process. To do this follow this procedure:
Click Start.
Hope this helps. Please rate helpful posts.
94
