Help with cwcli
Solaris 10, LMS3.2, RME4.3.0
I'm trying to export rme devices into an XML format and tried to use one of the command and it retured with the following error. I have more than 450 managed devices. What I could be doing wrong?
cwcli export inventory -u admin -p admin -f myinv.xml
cwcli export inventory -u admin -p admin -device device%
og4j:ERROR setFile(null,true) call failed.
java.io.FileNotFoundException: /var/adm/CSCOpx/log/license.log (Permission denied)
        at java.io.FileOutputStream.openAppend(Native Method)
        at java.io.FileOutputStream.<init>(FileOutputStream.java:177)
        at java.io.FileOutputStream.<init>(FileOutputStream.java:102)
        at java.io.FileWriter.<init>(FileWriter.java:61)
        at org.apache.log4j.FileAppender.setFile(FileAppender.java:284)
        at org.apache.log4j.RollingFileAppender.setFile(RollingFileAppender.java:198)
        at org.apache.log4j.FileAppender.activateOptions(FileAppender.java:239)
        at org.apache.log4j.config.PropertySetter.activate(PropertySetter.java:247)
        at org.apache.log4j.config.PropertySetter.setProperties(PropertySetter.java:123)
        at org.apache.log4j.config.PropertySetter.setProperties(PropertySetter.java:87)
        at org.apache.log4j.PropertyConfigurator.parseAppender(PropertyConfigurator.java:637)
        at org.apache.log4j.PropertyConfigurator.parseCategory(PropertyConfigurator.java:595)
        at org.apache.log4j.PropertyConfigurator.parseCatsAndRenderers(PropertyConfigurator.java:522)
        at org.apache.log4j.PropertyConfigurator.doConfigure(PropertyConfigurator.java:412)
        at org.apache.log4j.PropertyConfigurator.doConfigure(PropertyConfigurator.java:309)
        at org.apache.log4j.PropertyWatchdog.doOnChange(PropertyConfigurator.java:665)
        at org.apache.log4j.helpers.FileWatchdog.checkAndConfigure(FileWatchdog.java:80)
        at org.apache.log4j.helpers.FileWatchdog.<init>(FileWatchdog.java:49)
        at org.apache.log4j.PropertyWatchdog.<init>(PropertyConfigurator.java:657)
        at org.apache.log4j.PropertyConfigurator.configureAndWatch(PropertyConfigurator.java:373)
        at org.apache.log4j.PropertyConfigurator.configureAndWatch(PropertyConfigurator.java:355)
        at com.cisco.nm.license.client.LicenseManager.<clinit>(LicenseManager.java:62)
        at com.cisco.nm.rmeng.common.VerifyRMELicense.validate(VerifyRMELicense.java:70)
        at com.cisco.nm.rmeng.cli.framework.CwCli.doStuff(CwCli.java:151)
        at com.cisco.nm.rmeng.cli.framework.CwCli.main(CwCli.java:283)
SUMMARY
        Failed: export: Could not obtain any devices.
Recommended Action:
1.Check whether devices are in RME.
1 ACCEPTED SOLUTION
Re: Help with cwcli
Try this instead:
./cwcli export inventory -u admin -p admin -device %
Re: Help with cwcli
Try this instead:
Re: Help with cwcli
  • That did it, thank you.
203
