Help with this OID: 1.3.6.1.4.1.9.9.171.1.3.1.30
Hi all!
We have VPN Tunnel's lan-to-lan, between our branch and central site.
We need an IOD to report when a VPN tunnel (connection) down.
This OID: 1.3.6.1.4.1.9.9.171.1.3.1.30, returns the following:
snmpwalk -v 2c -c 'xxxx' 192.168.165.3 1.3.6.1.4.1.9.9.171.1.3.1.30
SNMPv2-SMI::enterprises.9.9.171.1.3.1.30.0 = Counter32: 0
This 0 number (Counter32: 0) means that all VPN's are active? there was no fall?
This OID serves just what we need?
Details of the OID:
Object: cipSecGlobalSysCapFails
Type: Counter32
MIB: CISCO-IPSEC-FLOW-MONITOR-MIB
Description: The total number of system capacity failures which occurred during processing of all current and previously active IPsec Phase-2 Tunnels
Apreciatte any help.
Thank you.
1 ACCEPTED SOLUTION
Re: Help with this OID: 1.3.6.1.4.1.9.9.171.1.3.1.30
No, these are total global stats for all phase 2 associations. They cover any associated error with a phase 2 tunnel establishment. This would mean that currently established tunnels as well as those which failed to establish would be counted.
This object only shows you one type of tunnel failure. If you want to get a total count of all failures, you need to sum up:
cipSecGlobalInAuthFails
cipSecGlobalOutAuthFails
cipSecGlobalOutEncryptFails
cipSecGlobalProtocolUseFails
cipSecGlobalNoSaFails
Hi jclarke!
Thanks for the feedback.
This OID's report VPN connections that failed?
For example: I have several VPN connections established in a L2L link, if it falls some connection, I will be informed (with this OID)?
Which of these OID's you recommend I use?
Thak you very much.
Jose Roberto
Each of these OIDs track a global IP Sec Phase 2 session failure. If that's what you want to track, then each of these OIDs are required to get the complete count of failures.
But this OID's are used for connections that are already established? Or they only inform connections that are under negotiation to establish the tunnel?
Thank you.
Hi jclarke!
Thank you very much for the help!
249
