High-availability architecture for CiscoWorks LMS
Dear Folks,
I am wondering whehter there is a high-availability configuration for CiscoWorks LAN Management Solution. If there is such an architecture or configuration please drop me a line (azods@yahoo.com).
Thanks in advance
Silver
Re: High-availability architecture for CiscoWorks LMS
No, the best you can get is having 2 servers running and theirby doubling all the polling and syslog traffic.
The advantage of a high available ciscoworks is also very limited. In general network management not critical.
A backup of all device onfigs in text format on another machine is all I ever advise.
Cheers,
Michel
also have a look at this thread:
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Expert%20Archive&topic=Network%20Infrastructure&CommCmd=MB%3Fcmd%3Dpass_through%26location%3Doutline%40%5E1%40%40.1dda9020/13#selected_message
I have seen some installations where someone was trying to add a high availability solution with handmade scripts and external RAID and not knowing the details of LMS prcesses and file system structure. This constantly lead to db inconsistencies while changing from the one server to the other. And what messed it up totaly was that you don?t get a message that something is going wrong - someday you just recognize (when you launch the right app) that it is not working as expected ...
Silver
Not entirely true. You need not double syslog traffic. We've instaled a couple of syslog NG clusters as the only logging targets and then have it distribute the results to multiple destinations.
If you choose the correct OS, number of servers, and number of redundant installations to match your environment you don't need HA.
I have about 5K mixed devices (60/40 routers/switches) across the US and through scheduling and thresholding I run the full suite of LMS 2.6 with little impact to the network.
282
