High CPU on 6500 VSS
I am also Observing the Same problem of High CPU on 6500.
Please suggest some Investigations
When i ran Debug as defiend by u . i found two problems
  • •-           Many configured ACEs have the “log” command. This means that a copy of  the packets will also be sent to the CPU. As you can see below:
ip access-list extended watch110_in
permit ip any host 172.27.192.10 log
permit ip host 172.27.206.2 any log
permit ip host 172.27.206.10 any log
permit ip host 172.27.206.126 any log
  • •-          In the netdr capture that I performed, I could see packets with a source IP of any of the above was also sent to the CPU.
2/ Redirects
  • •-          There are a number of packets which also have the destination index of 0x7F07
Please suggest
Everyone's tags (5)
495
