High CPU Utilization Nexus 7k?
Soporteco
Hi everyone.
We are a little concerned about many high peaks regarding CPU utilization on a Cisco Nexus 7k (version 6.2(2)). Peaks often reach 100%. Here's the behavior:
# show processes cpu history
    1 1    2 1 21 1 121 1 12  1121 2 14  121111 2 11 11   1   11
    037357837199965304462514663660738508320802251446670483845437
100
 90
 80
 70
 60
 50
 40                                   #
 30            #                #     #
 20   #    #   ## #  #     #   ##  # ##   ##    #  # #    #    #
 10 # # ########### #################### ######## ##### # # # ##
    0....5....1....1....2....2....3....3....4....4....5....5....
              0    5    0    5    0    5    0    5    0    5
               CPU% per second (last 60 seconds)
                      # = average CPU%
    899465895558965598634693655934549356699455996449946569555794
    350898451398942329713869146452267760759323381261483307572275
100  *     *    *         *         *    **    *         *    *
 90  **    *   **   **    *    *    *    **   **   **    *    *
 80 ***   **   **   **    *    *    *    **   **   **    *    *
 70 *** * **   **   ***  **    *    *   ***   **   **    *   **
 60 *** ****  ****  ***  ** * **    * *****   ***  ** * **** **
 50 *******************  ** ****  *** ***** ***** **************
 40 ******************* ****************************************
 30 ************************************************************
 20 *#****##***##**###***##***##****#***###**##****##**#*#**###*
 10 ############################################################
              0    5    0    5    0    5    0    5    0    5
               CPU% per minute (last 60 minutes)
              * = maximum CPU%   # = average CPU%
     11    1       1111    1      1           1 1  1    1    1   1   1
    900999909999999000099990999999099999999999090990999909999099909990999999
    900999909999898000099990889998099989999999090890899809988098809980899999
100 ************************************************************************
 90 ************************************************************************
 80 ************************************************************************
 70 ************************************************************************
 60 ************************************************************************
 50 ************************************************************************
 40 ************************************************************************
 30 ************************************************************************
 20 *##*####**####***##**#****#**********#***********************#**********
 10 ########################################################################
    0....5....1....1....2....2....3....3....4....4....5....5....6....6....7.
              0    5    0    5    0    5    0    5    0    5    0    5    0
                   CPU% per hour (last 72 hours)
I got this outputs from the Nexus:
# show processes cpu sort | ex 0.0
CPU utilization for five seconds: 23%/0%; one minute: 14%; five minutes: 15%
PID    Runtime(ms)  Invoked   uSecs  5Sec    1Min    5Min    TTY  Process
10294     54052210  14300533      3   4.50%   1.45%  1.96%   -    statsclient
 5345     12271480   3637181      3   1.91%   0.59%  0.51%   -    oc_usd
 5326      7924650   2329273      3   1.24%   0.44%  0.34%   -    sensor
 4444     23015630   8269523      2   1.05%   0.90%  0.89%   -    platform
 5216     22313520   8459875      2   0.95%   0.96%  0.97%   -    sysinfo
 5261      7913470   2572469      3   0.47%   0.29%  0.31%   -    diagclient
 5232     13726360   6699935      2   0.38%   0.52%  0.54%   -    diagmgr
 5108      4240770  130432066      0   0.19%   0.16%  0.16%   -    pdsd
 5322      3282920   3755142      0   0.19%   0.13%  0.13%   -    R2D2_usd
# show system resources
Load average:   1 minute: 0.88   5 minutes: 0.61   15 minutes: 0.56
Processes   :   1439 total, 1 running
CPU states  :   4.50% user,   10.00% kernel,   85.50% idle
        CPU0 states  :   6.00% user,   10.00% kernel,   84.00% idle
        CPU1 states  :   3.00% user,   10.00% kernel,   87.00% idle
Memory usage:   8260668K total,   4833504K used,   3427164K free
Current memory status: OK
# show system internal processes cpu
top - 11:20:10 up 14 days,  8:35,  3 users,  load average: 0.62, 0.56, 0.56
Tasks: 650 total,   1 running, 649 sleeping,   0 stopped,   0 zombie
Cpu(s):  5.7%us,  6.8%sy,  0.4%ni, 85.9%id,  0.0%wa,  0.2%hi,  1.0%si,  0.0%st
Mem:   8260668k total,  5333156k used,  2927512k free,    81408k buffers
Swap:        0k total,        0k used,        0k free,  1954140k cached
  PID USER      PR  NI  VIRT  RES  SHR S %CPU %MEM    TIME+  COMMAND
10945 ryramire  20   0  3868 1788 1148 R  5.6  0.0   0:00.06 top
 4444 root      20   0  199m  13m 9236 S  3.7  0.2 383:33.06 pfm
 5327 root      -2   0  180m  14m 8552 S  1.9  0.2 763:20.54 xbar_driver
 8109 root      20   0  278m  21m  12m S  1.9  0.3  99:24.51 pm
 9109 root      20   0  278m  21m  12m S  1.9  0.3 230:52.80 pm
 9836 svc-isan  20   0  255m  23m  14m S  1.9  0.3  48:06.21 stp
    1 root      20   0  1988  608  532 S  0.0  0.0   0:12.30 init
    2 root      15  -5     0    0    0 S  0.0  0.0   0:00.01 kthreadd
    3 root      RT  -5     0    0    0 S  0.0  0.0   0:02.10 migration/0
    4 root      15  -5     0    0    0 S  0.0  0.0   8:43.30 ksoftirqd/0
    5 root      -2  -5     0    0    0 S  0.0  0.0   0:48.33 watchdog/0
    6 root      RT  -5     0    0    0 S  0.0  0.0   0:02.13 migration/1
    7 root      15  -5     0    0    0 S  0.0  0.0   7:41.01 ksoftirqd/1
Is this a normal condition?. I've read this in Cisco:
 The Cisco NX-OS operating system takes advantage of preemptive CPU multitasking, so processes can take advantage of an idle CPU in order to complete tasks faster. Therefore, the history option may report CPU spikes that do not necessarily indicate a problem
Any recommendations?. Troubleshooting I can do? other useful commands? Normal conditions?
Thanks a lot in advance!
Fabio.
Hi ,
It looks fine to me ...
The Cisco NX-OS operating system takes advantage of preemptive CPU multitasking, so processes can take advantage of an idle CPU in order to complete tasks faster. Therefore, the history option may report CPU spikes that do not necessarily indicate a problem. However, if average CPU usage remains high compared to normal, baseline CPU usage for a particular network, you might need to investigate high CPU usage.
http://www.cisco.com/c/en/us/support/docs/interfaces-modules/nexus-7000-series-supervisor-1-module/116137-trouble-nexus7000-highcpu-00.html
Thanks-
Afroz
***Ratings Encourages Contributors ****
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
AFROJ AHMAD
HI Fabio,
If it happening not that frequently and you are not seeing any drops then it is fine.
also check the show log and see if there is any message to be concerened.  if you find any issue ,it would be best to troubleshoot the issue with EEM because spike happening Randomly .
check the below link for EEM config:
https://supportforums.cisco.com/document/64816/eem-script-nexus-7000-switches-monitor-cpu-utilization
Thanks-
Afroz
Hi!
I ran a EEM script to capture a "show proc cpu sort" as soon as a CPU spike was detected. The results were:
CPU utilization for five seconds: 72%/4%; one minute: 26%; five minutes: 16%
 4444     40205050  12415521      3  34.59%   7.25%  2.27%   -    platform
10294     94405200  24897408      3   8.26%   2.57%  2.20%   -    statsclient
 5327     81533840   3494387     23   1.33%   1.92%  1.86%   -    xbar_driver_usd
 5216     39232700  14916113      2   0.76%   0.72%  0.72%   -    sysinfo
 5108      7333350  226398351      0   0.19%   0.17%  0.16%   -    pdsd
 5222      6022890   1824713      3   0.19%   0.11%  0.12%   -    plog_sup
    4       903680  140208710      0   0.09%   0.03%  0.02%   -    ksoftirqd/0
    7       794690  116303858      0   0.09%   0.03%  0.01%   -    ksoftirqd/1
 3507      3066470  14086611      0   0.09%   0.03%  0.01%   -    sysmgr
CPU utilization for five seconds: 81%/4%; one minute: 27%; five minutes: 16%
 4444     40906590  12564873      3  38.73%   7.26%  2.27%   -    platform
 5948      2715690  31449621      0   6.69%   1.77%  0.43%   -    snmpd
 5327     82972760   3553756     23   2.58%   2.10%  1.89%   -    xbar_driver_usd
 5326     14357780   4218517      3   2.48%   0.42%  0.33%   -    sensor
 5880      2190560  46777275      0   2.39%   0.70%  0.18%   -    netstack
 5345     22232320   6582964      3   2.29%   0.54%  0.50%   -    oc_usd
 5232     24871960  12054356      2   2.00%   0.59%  0.55%   -    diagmgr
 5216     39797820  15159288      2   1.81%   0.81%  0.74%   -    sysinfo
 5261     14339770   4692217      3   1.33%   0.35%  0.33%   -    diagclient
 5865       897270  17393212      0   0.86%   0.26%  0.07%   -    pktmgr
 3507      3077410  14181344      0   0.47%   0.06%  0.02%   -    sysmgr
 5108      7461870  230410770      0   0.19%   0.16%  0.16%   -    pdsd
 6269       234950   1185977      0   0.19%   0.04%  0.01%   -    ethpm
CPU utilization for five seconds: 74%/4%; one minute: 31%; five minutes: 17%
 4444     40910890  12569459      3  41.17%   9.97%  2.92%   -    platform
 5948      2716500  31454618      0   7.75%   2.25%  0.55%   -    snmpd
 5880      2190750  46780136      0   1.81%   0.79%  0.21%   -    netstack
 5216     39797980  15160241      2   1.53%   0.87%  0.75%   -    sysinfo
 5327     82972820   3553760     23   0.57%   1.98%  1.87%   -    xbar_driver_usd
 5865       897330  17394277      0   0.57%   0.28%  0.08%   -    pktmgr
 3507      3077460  14182233      0   0.47%   0.10%  0.03%   -    sysmgr
   27       322310    921709      0   0.38%   0.03%  0.00%   -    kide/1
 5108      7461890  230411316      0   0.19%   0.16%  0.16%   -    pdsd
 5222      6128730   1856342      3   0.19%   0.13%  0.14%   -    plog_sup
 5322      5942590   6780564      0   0.19%   0.12%  0.13%   -    R2D2_usd
 5102         8910    303848      0   0.09%   0.00%  0.00%   -    vshd
 5217       153080    977776      0   0.09%   0.00%  0.00%   -    statsprofiler
 5230         4410    164888      0   0.09%   0.01%  0.00%   -    evmc
Is this a normal condition?. It seems he spikes are always related to the process "platform".
Thanks!
Hi ,
Thanks-
Afroz
