High memory usage on Catalyst 2960S
Hi, i have 14 SWITCH CATALYST 2960S that show high MEMORY usage from first use. the memory is about 93% full. Switchs are running "c2960s-universalk9-mz.152-1.E.bin" IOS. Is this a known issue with this IOS ? Can you please show me how to resolve it ?
1 REPLY
   Hi Are you having this
 Are you having this problem even after you start doing configuration on the switch?
 The running-config is saved in RAM and if you are working on the running-config, then I think RAM will be used.
297
