Community Member
High Tunnel Utilization Alerts
Does anyone know why a lot of the tunnel interfaces on my network would be setting "High Utilization" alerts in DFM? Some of these are showing like 569%! Whats up with that?
1 REPLY
Community Member
Re: High Tunnel Utilization Alerts
I'm guessing you're talking about GRE tunnels. The default bandwidth figure assigned to a GRE tunnel interface when it's created is 9kbps. This is the figure the SNMP agent returns when asked what the maximum bandwidth of the interface is. Do a "show int" and see the BW figure around the third line. Adjust this to something more realistic for the tunnel. e.g. 2Mbps
interface Tunnel99
bandwidth 2000
This can be difficult but I use the max bandwidth of the smallest link in the tunnel's path... if you know what it is. Otherwise just try and make a reasonable guess of the max throughput the you think the tunnel could get to.
104
