Community Member
Hits
I want to check the hits for Port no. 20 on our cisco router, please suggest if there is any command on cisco router(Without affecting any working scenreio).
Community Member
Re: Hits
Kindly reply pls.
Have to check the no. of hits for & from port no. 20 on cisco Router/Switches.
Community Member
Re: Hits
Dear Freidzs,
No reply from any-one.
Is this so difficult..? Or the question is wrong or there is no solution for the desired result.
Community Member
Re: Hits
Hi Sam,
Is there any NAT configured with this port?
Where and how you opened this port on your router
Naidu.
Community Member
Re: Hits
HI Naidu,
No there is no NATing configured on router.
We just want to check the port no. 20 hits "To" and "From" the access connectivity IPs on the router.
Re: Hits
Create an access-list with permitting first port 20 from any to any and then a line allowing all remaining traffic. Apply this ACL on the interfaces.
Then a show access-list will show you hits :
Extended IP access list 101
10 permit tcp any any eq tcp 20 (10 matches)
20 permit ip any any (6 matches)
This should not be production impacting.
126
