Webcast-Catalyst9k
Host line connectivity between PC and Cisco router 1841
for initial start up router's SDM ( http://10.10.10.1), i got connectivity on 2821 on gig ether port but i could not get connectivity to 1841....i tried 5 1841 with fast ethernet port from my celeron dell ? can you help me what is problem
1 REPLY
Re: Host line connectivity between PC and Cisco router 1841
Hi Patel
You need to check whether you have http services enabled on your router and also the required tar files to run SDM from your PC.
You can check the same using sh run (http service) and using show flash: command you can verify whether you have the reqd files..
regds
232
