Webcast-Catalyst9k
hostnamechange.pl script check
Hi all,
If anybody can look at this for me to verify the script and make sure it looks correct would be great. I'm taking my lab ciscoworks server and replacing the production Ciscoworks server tonight after 8:00 pm EST
perl hostnamechange.pl - ohost hwpmg900 -nhost hwpmg608 -domain corp
1 ACCEPTED SOLUTION
Re: hostnamechange.pl script check
Actually, this may be a bug with the forum, but there looks like you have a space where you shouldn't. The command should be:
perl hostnamechange.pl -ohost hwpmg900 -nhost hwpmg608 -domain corp
Looks right to me. However, you don't need those arguments, as the script should be able to detect the change. It doesn't hurt to explicitly spell them out, though.
Got it....thanks for you input.
297
