How can I find unused ports using SNMP?
How could I use SNMP to walk certain parts of the MIB on a switch to find ports that have been unused for a length of time?
1 ACCEPTED SOLUTION
Red
Re: How can I find unused ports using SNMP?
The calculation will always be the same.
It will be sysUptime - ifLastChange
That will in effect tell you how long it's been since the ifOperStatus changed.
Red
First, you would need to find ifOperStatus (this would tell you if the interface is up or down).
Second, you would need to find ifLastChange (this would tell you the value of sysUpTime when interface went down).
Now, you would need to find sysUpTime (this would tell you how long the device has been up for).
Note: sysUpTime is in timeticks (in hundredths of a second).
Walking sysUptime and understanding it is easy; it's simply the uptime of the device -
system.sysUpTime.0 = Timeticks: (3124188865) 361 days, 14:18:08.65
Walking ifOperStatus and understanding it is easy as well; it's simply an up or a down for that interface. This is the output from 1 interface:
interfaces.ifTable.ifEntry.ifOperStatus.1 = up(1)
Walking ifLastChange and understanding it is a bit more difficult. This is the output from 1 interface:
interfaces.ifTable.ifEntry.ifLastChange.1 = Timeticks: (4322) 0:00:43.22
The part I don't understand is how to interpret the results.
Can you shed some more light on how to interpret the results?
Red
Looks like this interface has been up for a long time.
ifLastChange.1 is returning 4322, so the interface has been up since the router's up time was 43 seconds.
In other words, it looks like the interface has been up for more than 361 days (sysUpTime - ifLastChange).
Hall of Fame Super Silver
Does the User Tracking unused ports report (http://www.cisco.com/univercd/cc/td/doc/product/rtrmgmt/cw2000/camp_mgr/camp_4x/cmgr_403/u_guide/ut.htm#wp1280599) not meet your needs?
Hope this helps. Please rate helpful posts.
This looks nice but our Campus Servers are at 3.3.
I'm trying to find a way to do this from a command line so I can fulfill the current request.
IIRC, 3.3 supports the Data Extraction Engine (DEE). Extract the User Tracking data via that mechanism (I believe it's all there in 3.3, just packaged in a report under 4.0), parse it out and pipe the output to a results file after some expression matching and sorting. It can all be scripted in a command shell or via some VB code that you can execute from command line as a shell script (Unix) or compiled executable (Windows).
The DEE schema is documented in the 4.0 user guide. See specifically: http://www.cisco.com/en/US/products/sw/cscowork/ps563/products_user_guide_chapter09186a00802297ac.html#wp1034795
I have the DEE installed and will take a look at it. However, I would still like to know how to do this from the command line using the snmpwalk command. The results shown in Campus are only as good as the last discovery.
Red
Not sure if you saw my earlier reply to your snmp walks:
Actually, I did overlook your previous response.
Can you repeat how you calculated this using that interface?
Red
Walk the sysUptime of a switch, the ifOperStatus to find a port that is down then subtract the sysUptime timeticks from the ifLastChange timeticks of an interface that is down then divide that value by 8640000 to get the number of days a port has been down.
Now all I need is a script that reads a list of devices from a file, determines how many ports are on the switch then performs the calculations......
RESULT1= snmpwalk .1.3.6.1.2.1.1.3 - sysUptime
RESULTS2= snmpwalk .1.3.6.1.2.1.2.2.1.8 - ifOperStatus - Find down ports
RESULTS3= snmpwalk .1.3.6.1.2.1.2.2.1.9 - ifLastChange
DOWNTIME of a port= ( RESULT1 - RESULTS3 ) / 8640000
I find it hard to believe no one has scripted this...
Blue
SNMP cannot distinguish between NOTCONNECT and ACTIVE ports, can it?
Isn't this what ifOperstatus shows? Ports that are NOTCONNECT (down) and ACTIVE (up)...
johnsonr@nmscrme01 > snmpwalk 10.147.116.13 public .1.3.6.1.2.1.2.2.1.8
interfaces.ifTable.ifEntry.ifOperStatus.2 = up(1)
interfaces.ifTable.ifEntry.ifOperStatus.3 = up(1)
interfaces.ifTable.ifEntry.ifOperStatus.4 = up(1)
interfaces.ifTable.ifEntry.ifOperStatus.5 = up(1)
interfaces.ifTable.ifEntry.ifOperStatus.6 = up(1)
interfaces.ifTable.ifEntry.ifOperStatus.7 = up(1)
interfaces.ifTable.ifEntry.ifOperStatus.8 = up(1)
interfaces.ifTable.ifEntry.ifOperStatus.9 = down(2)
interfaces.ifTable.ifEntry.ifOperStatus.10 = down(2)
interfaces.ifTable.ifEntry.ifOperStatus.11 = down(2)
interfaces.ifTable.ifEntry.ifOperStatus.12 = down(2)
interfaces.ifTable.ifEntry.ifOperStatus.13 = down(2)
interfaces.ifTable.ifEntry.ifOperStatus.14 = down(2)
interfaces.ifTable.ifEntry.ifOperStatus.15 = down(2)
interfaces.ifTable.ifEntry.ifOperStatus.16 = down(2)
interfaces.ifTable.ifEntry.ifOperStatus.17 = down(2)
interfaces.ifTable.ifEntry.ifOperStatus.18 = down(2)
interfaces.ifTable.ifEntry.ifOperStatus.19 = down(2)
interfaces.ifTable.ifEntry.ifOperStatus.20 = down(2)
interfaces.ifTable.ifEntry.ifOperStatus.21 = down(2)
interfaces.ifTable.ifEntry.ifOperStatus.22 = down(2)
interfaces.ifTable.ifEntry.ifOperStatus.23 = down(2)
interfaces.ifTable.ifEntry.ifOperStatus.24 = up(1)
interfaces.ifTable.ifEntry.ifOperStatus.25 = down(2)
interfaces.ifTable.ifEntry.ifOperStatus.26 = down(2)
interfaces.ifTable.ifEntry.ifOperStatus.27 = up(1)
interfaces.ifTable.ifEntry.ifOperStatus.28 = up(1)
Blue
Arghh, I meant to say NOTCONNECT and DISABLED. Both seem to show as "down" in ifOperStatus.
Red
You would have to look at ifAdminStatus to differentiate between NOTCONNECT and DISABLED.
The IP Network browser piece in Solarwinds does this.
http://www.solarwindssoftware.com/images/tools/ip_network_browser_lg.gif
2456
