Community Member
How can I restore out of box configuration on Cisco device?
The new Cisco devices (routers and switches) are coming with some default (out of box) configuration, but not without configuration, not with blank configuration.
I realized that there is some command that can restore thе default configuration. But I can't find it.
What is this command? Anyone does it know?
Thanks in advance!
Best Regards,
Tsvety
Go into enable mode and type
write erase
yes to all the prompts
then type reload
Should do it
Mike
Community Member
I don't know to have a blank configuration after that.
I want to restore the configuration as it was when the device is new, when the device is coming from Cisco. For example with access class 23 and so on...
Did you try the command?
Hall of Fame Super Silver
Mike's suggestion was correct. I would only add that one needs to erase vlan.dat if you have a switch that was used elsewhere. Cisco procedure linked here (for switches) and here (for routers).
Even a brand new factory-fresh box will have SOME configuration bits on it. A skeleton configuration - the default VLAN 1, empty interface definitions, etc. will always be there. The only way to remove everything would be to erase flash altogether forcing one to boot in rommon (not very useful).
525
