01-12-2006 05:37 PM
How do I access data from a PCMCIA flash disk in a 12416 Router? The disk is inserted in slot-1.
For example:
If I use command "dir <device>", what should I fill up for the <device> field.
01-12-2006 05:53 PM
There should be two slots on the device where you can insert PCMCIA flash cards: slot0 and slot1
Depending on which of these you have got the card in, type in:
dir slot0: OR
dir slot1:
Also, you can try the commnad 'show file systems' which will display a list of installed file systems.
Hope that helps.. pls rate helpful posts.
Paresh.
01-12-2006 05:57 PM
I also figured it out using command "dev,"
Kenneth
