Community Member
How do I filter incoming log files to the syslog
The local administrator wants to see all events in his local buffer, and we are successfully exporting that to a global syslog file, which I review weekly. He wants to see all entries, including level 7, but I only want level 5 (and higher)entries in the syslog file. The Cisco information on logging-filtered is confusing. I understand I can grep the final file, but I'd rather not get all the Level 6 and 7 entries in the global syslog. thanks.
Re: How do I filter incoming log files to the syslog
You can do:
logging buffered debug
This will send ALL messages to the built in logging buffer.
Then:
logging trap notif
That will send all level 5 and higher messages to your syslog server.
If you want to do more finer-grained filtering than that, you will need to create Tcl filter scripts which can be applied to different logging destinations. In this manner, you could filter out level 6 and 7 messages to one syslog server while keeping them unfiltered to another. Such a filter would be trivial. Something like this would work:
if { $::severity > 5 } {
return ""
return $::orig_msg
For information on the Embedded Syslog Manager can be found at http://www.cisco.com/en/US/docs/ios/12_3t/12_3t2/feature/guide/gt_esm.html .
Community Member
Thanks Joe,
It's been a very long time since I did programming or scripting. The file name is syslogX, and I've confirmed the tclsh file on my server. I ran chmod 777. The first line as #!/usr/local/bin/tclsh. What am I missing? thanks
This filter script is to be loaded on the router, or on a network server. It needs to end in .tcl. You then configure the filter:
logging filter flash:filter.tcl
Then, you specify which destinations are to be filtered. For example, to filter 10.1.1.1 while leaving 20.1.1.1 unfiltered, do:
logging host 10.1.1.1 filtered
logging 20.1.1.1
270
