Hi Team,By mistake i have been deleted root credentials on my NCS-5504 XR . Now i am unable to login router. Any procedure how to recover the credentials.RegardsSalman+919871873874
The content you are looking for has been archived. View related content below.
Hi, Kindly share the upgradation procedure and configuration of Cisco NCS-5504 Router(XR-Platform). Thanks Abhishek
We have a switch to our Wireless Access Points. We are getting repeated flapping of port notifications in our SYSLOG. Any idea why this would be happenin?
I'm trying to have EEM script where I run the script manually and it display the output of the results in the session but for some reason I'm unable to do so. This is what I have so far(config)#event manager applet TestCommand(config-applet)# event n...
Hello , Could you help me to reset the password on a Cisco Nexus N3K(C-31108TC-V). I ain't got access to CLI throught ssh or console port
I’m not sure if I’m posting this in the right spot; I’m new to this needing help with setup of a device. I’ve been trying and failing at setting up my 5506. I have a few questions I think if I can get cleared up I can maybe get this working. Please h...
Hello, I am attempting to configure a Windows Server with the NPS role to permit admins to log into our Catalyst switches using standard AD credentials. I've got things setup per a few different guides I've looked over, but on each login attempt the...
I want to enable SNMPv3 on a Cisco router, v1/v2 is fine but v3 refuses to work. Can you help?
Hello, Je désire resetter le mot de passe d'un Switch Cisco Cisco N3K(C-31108TC-V). Je n'Ai pas accès au CLI via ssh ou console port. Merci pour vos retours
I am using the Embedded Packet Capture feature on a C8200L-1N-4T router.I have the capture and need to export it to our TFTP server.When i run the following command:8200_RTR#mon cap DMVPN export tftp://192.168.1.146/Community.pcapI get the following ...
I'm having problems setting up my home network using Cisco2921 for the first time. It has the basic licenses only. Below is the running config followed by my adapter settings. Any assistance would be greatly appreciated. Thank you.Current configurati...
Hello!I have setup lab environment for test rogue on wire solution.List of Devices,- PI 3.10.2- SW C1000 (PoE) - fw 15.2(7)E7- WLC 5520 (Connected to SW C1000) - fw 8.10.162- AP C9120 (Connected to SW C1000) - fw 8.10.162I have plug the rogue AP to S...
I have a couple of Cisco Firepowers that I can access thru SSH or the FDM, but I can't console to them?-Software version: 7.0.5-72-Configured with primary and secondary-Base license-Not using FMCCan someone tell me how to get console access? Thank yo...
Hello Everyone,I'm novice to networking. And below is the requirement I'm trying to figure out. Any leads would be greatly appreciated"You are working as an IT architect for a new startup business that grew faster than expected. they expanded to oper...
Hello,The DISA STIG, V-239941, asks that the following be configured:event manager applet BACKUP_CONFIG event syslog pattern "SYSLOG_CONFIG_I" action 1 cli command "copy startup-config scp://userx:xxxxxxx@10.1.48.10//opt/config_backup" action 2 syslo...
Subject | Author | Posted |
04-16-2024 04:45 AM | ||
04-16-2024 01:33 AM | ||
04-13-2024 12:00 PM | ||
04-11-2024 05:18 AM | ||
04-08-2024 08:39 AM |
User | Count |
7 | |
2 | |
1 | |
1 | |
1 |
