How Do You Generate a 2048bit CSR for a Third Party SSL Certificate for LMS 4.0.1?
Our site requires Third Party SSL certificates to be installed on our servers.  We have an agreement with inCommon. I have to supply a CSR in order to obtain the SSL certificate.
My installation is on a Windows 2008 server and I had the self-signed CSR already but it is only 1024 bits.  Is there someplace in the GUI or OS where I can change the encryption?
1 REPLY
Hall of Fame Super Silver
This is a shot in the dark, but since CiscoWorks is using (I believe) Tomcat as the web server, could you run keytool to generate the CSR?
http://help.godaddy.com/article/5276
You could also use an online CSR gererator such as:
http://www.gogetssl.com/eng/support/online_csr_generator/
The key (pun intended) is having the private key on your server so that when you get the signed certificate and install it (using sslutil) it will be usable.
Hope this helps.
595
