How to add devices in LMS3.2?
ericohermoso
This is my first time to install LMS3.2. I successfully installed the software but I don't know what is the next procedure and I don't know how to add devices. Please, How can I add devices to the LMS.
thank you,
5 Replies 5
Leo Laohoo
Go to Function > under Common Services > Device and Credentials > Device Management.
You can enter devices one-by-one or do bulk transfer (CSV file or text file).
Is there any configuration needed to the router/switches like snmp?
thank you
Make sure your SNMP community string are all the same.  Also, if you have the default "public" and "private", for security sake, please change it.
Hai,
You need to assign SNMP comunity string on routers and swiches which your going to addd in LMS 3.2.
Be care with Read only and read write community string .
Read only to only fetch config, view device details.
Read write to change configuration on router through LMS.
regards,
M.K
Do I need to configure the username, password and protocols to discover the devices?
thank you
