How to archieve configuration in ciscoworks for 4404 wireless controller
rana.samir
Hi All,
How can we archieve configuration in ciscoworks for 4404 wireless controller.
Thanks in advance.
Samir
Joe Clarke
The WCS controllers are supported just like any other device.  Make sure you have either telnet or SSH enabled for config archive transport, then before a Sync Archive on your controllers.  RME will log into them, and run "show running-config" to extract the configuration.
Joe Clarke
Hi Joe,
Thank you very much for your reply.
Samir
