How to capture Catalyst traffic
Hello friends.
I want to capture all traffic in my net. I have a 5 switch stack of Cisco 3750 Catalyst.
How can I do it?.
Thanks.
Gold
Re: How to capture Catalyst traffic
You can use SPAN session - traffic from all ports (VLANs) can be mirrored to one port
check following link
http://www.cisco.com/warp/public/473/41.html
M.
Very good link but I want another solution more easy for me if it can be possible.
Red
Since these are switches, you will have to span the ports in order to capture the traffic.
I discovered that I can configure span ports with Cisco Network Assistant
I open a span session in a port of one of my stack switches.
What I must to configure encapsulation: native o replicate?. Must I to choose any vlan?
Wht I must to do after?.
135
