Community Member
how to change configuration using SNMP
i have 3560 device on remote site and due to some wrong configuration tacac communication is getting failed and switch is now directly asking for password however it gives authorization failed when i put in.
is there any way by which i can fetch the config via snmp and change configuration and reconfigure the switch.
i tried using cwconfig features but getting authentication failed error is popping up.
1 ACCEPTED SOLUTION
Re: how to change configuration using SNMP
You can use any snmp utlity...you would just query / set the same snmp OID's
Community Member
Hi davistan,
this require hpopenview and solaris. i dont have any of them, is this still possible ?
396
