How to configure IP accounting
Hello there,
I wonder if you can tell me how I can configure IP accounting on routers ? Assuming that feature set allows to do that ?
Alex
1 REPLY
Re: How to configure IP accounting
you can do it with normal ip accounting command under the interface on which u want to enable the accounting..
interface fastethernet 0/0
ip accounting
also refer this link for more options available in conjuction with the command..
http://www.cisco.com/univercd/cc/td/doc/product/software/ios124/124cr/hiap_r/apl_i1h.htm#wp1201321
regds
94
