Community Member
how to delete old events in fault history?
hi,
I wanted to delete all my old alerts in DFM. I am aware that ciscoworks has only last 31 days events/alers in the fault history, which basically would be in the database dfmfh.db. My problem here is that i have more than 183000 alerts in the fault history for a month, I dont wanted all of these alerts now.
/gopi
1 REPLY
Re: how to delete old events in fault history?
There is no way to control the amount of time data lives in Fault History.  As you pointed out, data will be retained for one month.  You can reinitiatize the Fault History database, but that would destroy all FH data.
268
