How to disable Tftp on Cisco Works 1.5?
We have a problem on 3Com sofware to backup switch configuration.
There is a conflict with Cisco Works 1.5.
The two sotfware are installed on Windos 2003 Server.
Is it possible to disable Tftp demon on Cisco Works without unistalling?
Davide
Red
Re: How to disable Tftp on Cisco Works 1.5?
Go to the Services and stop the CWCS tftp service.
Just remember that if you disable to CiscoWorks tftp server you will lose some functionality within the application, such as config archive.
Thanks for the info...we restart windows server and magically we have seen the services! :)
253
