how to enable automatic startup on LMS 4.1 ?
Hello all,
i wanna ask a question regarding automatic startup on lms 4.1, i have installed my LMS 4.1 on esxi  4.x . but recently my server sometimes down because the electricity problem. and when my friend push the power button to start the server, the LMS is not automatically active. is it possible to make it automatically active soon after my server power up ?
thanks before.
1 ACCEPTED SOLUTION
I think this explains it
http://blog.michaelnugent.ca/2009/05/esxi-autostart.html
"You need to select the ESXi server, go into configuration and then go  into VM Startup/Shutdown.  Then you need to use the 'up' and 'down'  buttons to move between categories."
Cheers,
Michel
Blue
Re: how to enable automatic startup on LMS 4.1 ?
LMS should start up automatically by default, unless you had deliberately disabled the auto-startup, which doesn't sound like the case. Given the power issues, it's possible LMS has failed to start up automatically due to database corruption, so you might want to examine the pertinent LMS logs for indication of any process failures, such as in
/var/adm/CSCOpx/log/daemons.log (on Solaris and the LMS appliance) or NMSROOT\log\syslog.log (on Windows) files.
Below are some reference docs:
LMS Processes Down - What to do
https://supportforums.cisco.com/docs/DOC-14520
LMS Daemon Cheat Sheets up to LMS 4.0
https://supportforums.cisco.com/docs/DOC-8798
LMS Database Troubleshooting
https://supportforums.cisco.com/docs/DOC-8796
Cheers,
Michel
thanks all.
366
