08-30-2006 04:35 PM
Sir
if I wanna enable netflow in one interface of 6509,after I check,it hasn't "ip route-cache flow" command,can you tell me how to do?
Thanks!
08-30-2006 07:06 PM
On 6500 switches you need to configure netflow globally to collect statistics from traffic that flows through the switch.
Check out the link below for more info.
http://www.cisco.com/en/US/products/hw/switches/ps708/products_configuration_guide_chapter09186a0080160a2b.html#wp1047637
HTH,
Sundar
Log in to Community
