how to implement SCP safety-measures ? eg: there's no scp in management plane
nlariguet
ip scp server enable ... working fine
how do I restrict scp access on the router ?
I see I can't issue:
control-plane host
management-interface whatever allow https ssh ... scp
I encountered a similar problem with the https service when you change the default port 443 to something else: you loose the ability to restrict it with the management plane
any suggestions ?
0 Replies 0
