Community Member
How to import devices in RME 3.5 Inventory using CSV or DIF
Can anyone tell me how I can import devices in RME Inventory using CSV or DIF files & also where can I locate CSV or DIF files.Any help would be appriciated.
1 REPLY
Community Member
Re: How to import devices in RME 3.5 Inventory using CSV or DIF
This is explained in the following link:
Importing Devices Into Your Network Inventory Using CSV and DIF Files
http://www.cisco.com/warp/public/477/RME/troubleshoot_rme_inventory_import.html#topic3
Examples of the files can be found in CSCOpx\example\import on the CiscoWorks server
If this helps, please rate my post :)
Marcus
113
